Displays the XNV feature configuration for the specified port and information for all VMs authenticated on the port.
| port_list |
Specifies one or more ports or slots and ports. |
N/A.
None.
The following command displays the XNV configuration for port 1:20 and the authenticated VMs:
# sh vm-tracking port 1:20
VM Tracking Global Configuration
VM Tracking : Enabled
VM Tracking authentication order : nms vm-map local
VM Tracking nms reauth period : 0 (Re-authentication disabled)
VM Tracking blackhole policy : none
Port : 1:20
VM Tracking Dynamic VLAN : Enabled
Flags
MAC AP IP Address Type Value
00:00:00:00:00:11 LBI 255.255.255.255 VM
VLAN Tag 100
VR Name VR-Default
VPP lvpp1
IEP
EEP
Flags :
(A)uthenticated : L - Local, N - NMS, V - VMMAP
(P)olicy Applied : B - All Ingress and Egress, E - All Egress, I - All Ingress
(C)ounter Installed : B - Both Ingress and Egress, E - Egress, I - Ingress
Type :
IEP – Ingress Error Policies EEP – Egress Error Policies
Number of Network VMs Authenticated: 0
Number of Local VMs Authenticated : 1
Number of VMs Authenticated : 1
This command was first available in ExtremeXOS 12.5.
